Smurfette the 2wd B2
zachwabbit
Oct 18, 2017
211
Jamul
Go rubber on the bushings. Poly doesn’t like the twisting motion the beams will see.
Bronco II’s have a little spot in my heart.
Yeah that’s exactly what John said. Figured it was still worth getting another opinion though before I shell out the cash.
zachwabbit
Oct 18, 2017
211
Jamul
So might be picking up some used F31 Deavers soon, really would like to keep the ride height below 4” though. Can this be achieved without flipping the hangers? Wouldn’t a longer shackle with the stock hanger result in a lower ride height? Or would that force the leaf pack into an undesirable wider arc? Still planning to run the 10” shocks I have with longer mounts under the bed, and an Expo 8.8.
zachwabbit
Oct 18, 2017
211
Jamul
Here's what a BII looks like with F31's flipped shackles and 33" tires. I think he moved the hangers back and longer shackles which helps with the way the leafs cycle.
Haha that’s funny I just messaged him on Instagram asking about his setup yesterday. Giant hangers and 6” shackles if I remember right
zachwabbit
Oct 18, 2017
211
Jamul
Had an idea for no apparent reason.. my last two brain cells eek out useful stuff sometimes. What if I run the F31’s in a spring under configuration instead of spring over? Stock I’m spring over, but since I’ll be swapping to an Expo 8.8 and Expo’s are spring under, couldn’t I theoretically leave the stock Expo spring plates and end up with a lower rear ride height? I’ve seen Expo’s with spring under Deavers that seem to work well, so why not?
chewy0288
3,159
67
near sacramento
I imagine your spring mounting width would be too narrow, to fit on the factory perches, I know rangers are. And I think you will also run into clearance issues between your axle:frame and differential:floor.
Reactions: zachwabbit
