Solo motorsports Toyota Fabricated Spindles/lower uniball and steering
jonathanfedel
198
Arizona
I have a new toyota fabricated spindle from solo motorsports that was originally for my tacoma build. im selling because i have i beamed my truck since then.
here are the details from solo's site
2WD Fully-Fabricated 3″ Lift Spindles 1st generation Toyota Tacoma/Tundra/Sequoia
Spindle offer a huge gain in strength compared to stock. No more breaking of the factory upper and lower ball joints associated with the stock spindles.
The Toyota Fabricated 2WD lift spindles will improve on and off-road handling by increasing the track width 2″ per side. The Fabricated Spindles will gain more ground clearance. These spindles will NOT require you to compress the coil spring to achieve a higher ride height.
use a Dana 44 hub assembly. Which will make servicing the spindles easier on or off the road.
this includes the solo motorports lower Toyota Lower Ball Joint Conversion to 1″ Uniball with Steering. All Full Fabricated Spindles require an upper control arm with a 1′ uniball.
will work with total choas kit.
https://solomotorsports.com/shop/parts/toyota-parts/suspension-toyota-parts/fully-fabricated-toyota-spindles/ paid $1950
https://solomotorsports.com/shop/parts/toyota-parts/steering-toyota-parts/toyota-lower-ball-joint-uniball-conversion/ paid $1550.00
spindles and steering are brand new
asking 2000. will ship if buyer pays shipping. located in arizona. call or text me at 623-556-6634 no interested in traded. no i will not except less than asking.
