Sort of like a Jeepspeed XJ
Bertismyname
Oct 1, 2018
535
168
Dent fix tools makes an air powered undercoat removal tool that works really well for a decent price. Or use a twisted wire cup on your grinder. Heat gun and a scraper works well too. Clean with acetone then sand away paint. Makes welding much easier and cleaner.
SByota
312
71
I have been thrashing like crazy to get this pile ready for KOH. It’s far from done, but it’s good enough to take and put some dirt miles on it.
I’ve been driving it around town for a few days now. No issues other than it’s really fucking loud inside. The noise is to be expected though, no carpet, no headliner, no real interior.
I definitely want to lower the front down, it’s sitting a little tall. I think the added caster from lowering it will help with the drive ability too. I only have like 4° right now.
The co driver LOVES riding in it and hitting the dips as fast as we can.
SByota
312
71
Been driving the Family Truckster around town for about a week now. Put around a 100 miles on it. Nothing really exciting to report, it ventured onto the freeway and it did fine, the 4:88 gears are perfect for 35’s.
I’m excited to take it out to KOH and just cruise around and see how it does. I’m pretty sure the rear shocks are going to need stiffer valving, but I’m not messing with it until I get back from the desert.
Whipped up a quick light bar from some original bumper brackets, a chunk of tube and some of china’s finest LED lights. They work decent for the money.
SByota
312
71
King of Hammers was a blast. The XJ did great, no issues. Put about 100 dirt miles on it. From sandy washes to some 4Lo stuff.
The front feels good, the rear shocks need stiffer valving for sure. The transition to the air bumps is really harsh. I’m going to try stiffer valving in the shocks and lower the nitrogen pressure in the bumps. I’m not using all the travel. Initial set up was a total guess. 200 PSI was too much for such a mellow set up.
I drove it like a pussy pretty much all weekend. I did charge one set of whoops and was quickly reminded that 10”/12” of travel really isn’t that much. Hit the face of a decent whoop and it launched me into the air pretty good.
A solid trip, nothing broke and lots of smiles. I can’t wait to do some more work and put it back in the dirt
SByota
312
71
Have not worked on it much since KOH. Just small BS issues. Moved the brake line inlets on the calipers so they don’t crash into the shock mounts anymore. Clipped a coil of the front springs to level out the ride height. Swapped out the clevite style rubber bushings on the front axle for a Currie Johnny Joint.
The co-driver still loves it and asks for rides all the time. I really need to pull the rear shocks and re valve them. Also need to finish the cage, build bumpers, build sliders.........it never ends.
SByota
312
71
The rear shocks have always felt soft and squishy. I pulled them apart and found out why.
In an attempt to make my single shock work it’s best I put in a flutter stack with a .012 cover shim. I also really didn’t know about free bleeds( all 3 were open), I also used the smallest shim as the “fulcrum” shim. I used the .012 I had from the straight stack that was in the shocks when I first opened them up. Like a retard I never replaced it, even though I had one, when I put the stack together.
So combine a pretty thin cover shim, 3 free bleeds, a very small diameter flutter fulcrum and missing the last high speed shim equals very little if any damping. No wonder it was hitting the bumps so hard.
I switched it up to a straight .015 stack and left all 3 bleeds open. Mainly because that’s what I had on hand and wanted to get it back together.
Driving it around town it’s like a different XJ. Much more planted and definitely feels better through dips and over the random terrain I can find around my house. I’m excited to see how is does in the dirt.
I also replaced the high speed duct tape that was sealing the rear shocks to the holes I cut in the rear fenders. Still needed a little gorilla tape though.
Reactions: the bodj
2,889
948
Did you cut a hole in the rubber sheet slightly smaller than the shock body, stretch it around the shock, then self-tapper up the fender well? Regardless, looks like it will keep out the exhaust fumes, dust, and mud. Sweet!
Is it me or does that bump can look hammered?
