Spindles
20
2
Reno
Hello, i need some help with something that may be obvious. I attached a picture of a fabricated spindle I plan on purchasing along with a long travel kit for my ranger. I am not familiar with spindle assembly, so I’m hoping someone can tell me what’s required to attach brakes, a hub and bearings, and a wheel to this spindle. Thank you for any help
exp24
177
6
Nor cal
You will need a snout, that's where the wheel bearings, crush sleeve and hub all connect to. That right there depends on what application you are running for size of tire and abuse you intend to do. Camburg, BMS ect all sell the set up along with a brake set up.
Nov 25, 2019
20
2
Reno
Thank you. I am still an amateur in the prerunner scene, so I am unfamiliar with the setup of that particular spindle setup. I appreciate the help
10,440
1,200
You would be better off buying a complete kit. There are no provisions for brakes or steering on that spindle. Also, is it the right height? Good scrub radius? If you don't know the answers to those, a complete kit from someone like JD Fab, BTF or Camburg will keep you from a lot of headaches and expensive redo's.
Nov 25, 2019
20
2
Reno
Could you recommend a kit for a ranger? I know it’s pretty diverse but I’m hoping for something that will work for me, and I don’t have an understanding of how spindle assembly’s work, especially with the type of spindle in the picture
armrunner
Feb 12, 2006
2,483
13
Bakersfield, CA
BTF Fab
Camburg
HM Motorsports
Vegas Dezert Fab
Theres a ton of people out there honestly.
