Stupid question but I still help
YungICY
146
Hey guys I’m thinking about finally getting around to doing the swing steering on my unequal length ranger. I’m just running the stock knuckles and I’m curious what you guys have done as far as drilling out the hole on the factory steering arm to run a bolt through the heim and arm. I bought some heims with I believe 5/8ths misaligns ( I bought them a while back so I don’t remember exactly but it was a smidge bigger than the larger taper on the factory arm) but that seems like too much to hog out. What have you guys done here?
Also, does anyone know how to access the archived threads on here? I was able to find a thread or two that probably answered my question for me but they were archived and the link would redirect to the home page.
crazyracer
Tres Cuatro Tacos
Sep 27, 2006
2,687
148
Pacific Beach, CA
I used a reamer for my knuckles that punched out the diameter to 5/8" if I recall correctly. Did it with a drill without removing the knuckle - super easy. Reamers are expensive though, so I borrowed one from a buddy.
Can't help with your 2nd question.
YungICY
146
Wait, so did you still use a tapered style bolt or just go 5/8ths clean through?
I’m just worried about if I go 5/8ths clean through the remaining material will be too thin.
6,379
866
mine use a 5/8 bolt on ranger knuckles. definitely plenty of material left over
YungICY
146
Thanks guys. I appreciate it.
And on a side note I was able to access older archives by using the search bar at least on the mobile version of the site.
Bertismyname
Oct 1, 2018
934
322
reamers are cheap at k surplus here in san Diego. If anyone on here is in the s.d. area and hasn't been there you are missing out big time. Bought 5/8×5" f911 there. Spent 15 dollars for 8 of them and a shit ton of half inch grade 8. They do online sales too.
crazyracer
Tres Cuatro Tacos
Sep 27, 2006
2,687
148
Pacific Beach, CA
I used a reamer that leaves a nice clean straight bore. Coulda drilled them with a two-flute drill, but a reamer leaves a better hole finish.
