Sway away resi replacement
2,898
3,139
One of mine seems to be fucked and don’t want to keep nitrogen out of the oil no matter the o-ring installed or wear ring on the ifp (installed a slightly thicker metric o-ring to help seal, no dice).
Any of the other mfg resi’s cross over? Need to get one asap
7,136
10,621
I have some small 6” long cans that you could try
7,136
10,621
What the fuck, over? I never had issues with those fucking shocks. Maybe they started dripping because of the 70’s porn they were wrapped in?
oorracing
Jan 15, 2006
10,683
248
Long Beach Ca
Check the o ring grooves for wear/scratches. Also check the cylinder for the same.
Put a 1/4-20 bolt in your drill press, thread on the IFP, turn it on and use some scotch Brite to clean up the O ring groove on the piston, and use a scotch brite ball or make an attachment to hone the resi with. That works most of the time unless the part has a really deep scar in it
2,898
3,139
There ain’t a scratch in them. You can feel the difference when you put the ifp in. Nice and snug then loosens up 1/4 the way in. Feels like they got 300k miles on them. I’ll have to throw my bore gauge on them and take pics when I change them with Ryan’s resi’s. Maybe they need “hone marks”?
