Well the spindles fit right up, no problem but I did catch a rag on fire while cutting out the rusty floors with my plasma torch. That was exciting.
from this:
to this:
you'll notice that I probaby cut out more than was needed. If you take a look at where the forward cab mount steel is, you may notice there's a rearward slope to it. Well the factory floor angle slopes further rearward than the cab mounts for... some reason. The effect is that you lose some footwell volume, but it's not so noticable when you're high up on a bench seat.
It was a critical issue on my last truck with the low-mounted bucket seats. Driver fatigue over time due to bad leg angles.
The fix: make the "flat" section of the floor go all the way to the cab mount, and then turn upwards & follow the angle of the cab mount.
I needed to cut out the rusty stuff anyway.
The penalty will be exhaust pipe routing clearance. but that's a problem for later.
from this:
to this:
