JusSumGuoy
Old Skool Ford Freak
Feb 20, 2008
4,437
66
Huntington Beach, CA
Your cage idea sounds like what I was planning when I had my supercab. Have you seen autofab's body mounts with the poly bushing mount built into them? I think he only has them for the 80's-90's trucks but this idea can be utilized well here I think. You'll be making custom body mounts anyway on both the frame and the cab, so put some cage thought in early (if you haven't already) and you should be able to come up with a solid replacement.
*Edit* By "poly bushing mount" above I mean a tube mount, not just the basic body mount. These suckers: https://autofab.com/i-12006716-bronco-body-mount-to-cage-kit.html
Reactions: mikey09120
10,265
1,432
I'm doing the cab on my f100 basically welded to the cage and the floorboard will be welded solid. Thats how my Tacoma was and it wasn't too loud at all my dynamat and carpet. Hopefully my new truck won't be too loud with the big fox shocks and a v8.
Drayke
Always Baja Bound
Jan 29, 2007
1,137
462
Torrance
i mean, sure. but you could use the same argument for plating the whole frame. When is it enough?
Right now it's got ~4-5 inches from the cut to the back of the doubler.
Drayke
Always Baja Bound
Jan 29, 2007
1,137
462
Torrance
are you asking about a cab swap?
That almost certainly would have been easier. I'm working in a 2 car garage with almost zero driveway space. having 2 dead cars is not an available option for me.
10,265
1,432
Only problem it would eliminate is splicing the frame. Not a problem but eliminates something someone might things is a problem.
Just like my tacoma's trailing arms were a 2 piece so i can cut them on my 4x4 table and people said they would break. Well years of use and a 75mph rollover on the freeway they were as good as day one and no issue ever which is how i assumed they would be but internet fabricators know everything
Reactions: Drayke
