The Houndrunner
Rowdy Fitz
Apr 16, 2021
1,188
1,462
Nevada
Now thats a coil retainer!
Nothin like those mini stock ones with a tiny bolt!
Yes sir, I had the materials on hand to go overboard, so I did it. I learned a long time ago that over built doesn’t break at the worst possible time and place.
Rowdy Fitz
Apr 16, 2021
1,188
1,462
Nevada
Finally replaced the ball joints. Discovered that the the lower radius arm bolt had started to back out and I most likely hit it on a rock which broke the bung off inside the beam. Welded that back up, finished setting the caster and camber. While the ball joints were bad, it didn’t fix my camber issues. I’m going to try adding washers under the coils to get the camber right.
