WannaB4000
17,061
12,905
You shouldn't be cutting into anything motor support related. Unless it's that much different from a full size? Full size is just trimming back the bottom flange on the frame. Then box in that section.
17,061
12,905
Yes, if you don't it will crack eventually. That looks like it needs a lot more cut out than a fullsize. I would trim out what it needs, even into the side of the frame rail. Then plate it back in like a frame notch in the rear would be. Run the plate all the way into the cross member boxing it all in.
Smithsl160
May 5, 2020
81
118
33
Oklahoma
So I ended up just taking a small bit out of the lowermost flange. Once this was out, the next thing that bottomed out was the front driveshaft knuckle and the inside flange of the frame again. Decided to go ahead and halt the cutting there and call it good. The notch for the dif gave another ~1" of uptravel.
232832
232833
I will box this in via advise from the elders.
This additional travel made the bump stop mounts look and feel a bit more reasonable. Here is what I have so far. They still feel a little dainty, but the bumps should bottom out at the same time that the shocks land on their rubber stops.
232834
232835
