ZFG SXS build
1,262
663
Yes, but then shits spinning backwards. Same issue with trying to run a rear diff, ring gear ends up being on the wrong side.
No barge, we went over this. running a rear diff up front doesnt make it run backward, it just changes the drive side of the ring gear to the coast and coast side to the drive. you still get forward movement when put in drive though. put a IRS diff up front and call it done.
im surprised that the diff cover upside down works correctly. both low and high pinion 8.8 have the pinion off set to the left of the ring gear when looking from the rear to the front unless where the ports are, are on the bottom/top of the cover?
1,262
663
so flat out, the cover should have been right side up the whole time?
oh well, grind out like you said and truetrac it is! i dont really mind the lockrite in the front of mine at speed but that might be different in a TTB setup
