ZFG SXS build
13,014
4,993
Got out the big wrench.
220452
For the big nut.
220453
A little sketchy press action.
220454
And all broke down.
220455
Need to get some degreaser tomorrow to clean up all the parts and then reassemble it.
13,014
4,993
Machine. It just stopped. Panel was dead. Had to cut the power to reset. When I fired it back up the origin was .236 off on Y. Good thing it roached the endmill before it got to far. Reset the origin and called it a night. When I went out to finish it tonight it was .236 off again back to it's original origin. So it has 2 issues, the main board is locking up and the Y axis limit switch is not consistent. Replacement board off egay is 250$ but I need to figure out how to save and reload all the parameters. Assuming all the parameters are correct. With a machine this old it's all a crapshoot. May require a call to Haas. This is not something that I will put up with.
13,014
4,993
Some dumbass forgot to weigh the idler gear before he started whittling on it. Machining the second side right meow. It needs to go in the case before the diff cluster.
