You will have to build your own log manifold from what I can tell to use a bolt on but then your issue becomes making the computer use the vanes in the turbo properly. Unless you want to sit in the rig with a lap top and do a bunch of driving while logging vane position and trying to make adjustments in the computer, you will have to stick with some kind of stock modded drop in. I don’t even know if you can actually get the software to log and tune the rig properly.
This is your stock turbo map. Right now it’s pushing around 10lbs/min at 13psi to get your stock 90hp. That’s at around 4100rpm at it’s peak hours based on what I can find. No use going much past that unless a tune is going to open it up to hold power to 4500-4600rpm.
From what I can tell, everyone doing a shit load of fueling mods and even the Garrett vnt17 turbo are only netting around 160hp. “Technically” the stock turbo should be able to do that but I have a feeling the exhaust side becomes a big restriction and drive pressure goes through the roof making the map points go hard to the right and off the map
Even if you get enough air through this bitch, fueling looks to be a big issue to get you over the 200hp mark.
If you can find the fueling, I would really try to compound turbo this thing. Don’t worry about cooling the air between primary and secondary turbo, your water to air will do well because the idea is to keep both turbos in peak efficiency range so adding a ton of heat to the air shouldn’t happen. Remember the secondary turbo (your stock on in this case) goes under pressure from the primary and basically goes under its own atmosphere so if you apply 14.7 psi to the secondary and the secondary adds 13psi, the secondary has no idea it’s making a total of 27.7psi, it’s still happily in its map making 13psi and running efficiently.
I’ll see what I can figure out for a good compound turbo. Hx35 might work well.
